Convert Morph Volumes
Use the Morph Volumes: Convert tool to convert morph volumes to hexahedral elements and convert hexas to morph volumes.
Note: Converting complex morph volumes to hexa elements will generally result in the
loss of some edge detail, because hexas can only have (at most) one edge node.
This means that morph volumes with more than one node or handle along their
edges will be approximated with a single node between the corner handles. Morph
volumes are always converted into second order hexas, whether or not they
include such extra handles.
From the Morph ribbon, click the tool.
- Select Morph volumes/Hex elements to convert.
- Optional:
When converting hex elements into morph volumes, you can complete the following
steps.
- From the guide bar, click Convert.
