External Object
Add an external object to the report.
- Right-click at the Report or Chapter level and select
Or
From the Report ribbon, click the arrow next to the Add Item, then select External Object.
. - Below are the properties associated with the External Document entity.
- Name
- You can edit the name property of the External Object
item.Note: Once you select a file, the External Object name is replaced with the selected file name.
- File Path
- Select an external file using the file browser option.
Note: This module works similar to the Insert Object functionality in Microsoft Word. All files listed in the Insert Object functionality of Microsoft Word are supported in this module.Figure 2.
Restriction: Adding a secured or password protected document is not supported in the External Object module.
