2D Meshing
In this tutorial, you will create, adjust, and edit mesh.
Before you begin, copy the file(s) used in this tutorial to your
working directory.
In this tutorial you will:
- Create an initial mesh
- Adjust the mesh
- Edit the mesh
Create Mesh
In this step, you will create and inspect the initial mesh.
- Start HyperMesh.
- From the menu bar, click .
Browse to your working directory, select
BracketLeg_Start.hm, and click
Open.
The model opens in the modeling window.
From the Topology ribbon, select the Edit
Parameters tool.
In the Parameter Editor dialog, click
and browse and open the
crash_2mm.param file.
- Click Apply and close the Parameter Editor dialog.
Criteria tool.
In the Criteria Editor dialog, click
crash_2mm.criteria file.
- Click Apply and close the Criteria Editor dialog.
From the 2D ribbon, select the tool.
Figure 3.
- In the modeling window, select all displayed surfaces.
From the guide bar, click
For Element size, enter 2.5.
Figure 4.
- From the guide bar, click Mesh.
Adjust Mesh
If necessary, select the tool from the 2D ribbon.
Figure 5.
Set the density of the edges shown in Figure 6 to 12.
- Hover over an edge with a density of 12 and press to copy its settings.
- Hover over an edge you wish to change and press to paste the settings.
- If necessary, select Update from the guide bar.
Figure 6.
Tip: From the guide bar, click
and select
Auto update to automatically update the mapped
surface. -
Select the tool from the 2D ribbon.
Figure 7.
In the modeling window, select the two surfaces
highlighted in Figure 8.
Figure 8.
- In the microdialog, set Element type to Quads only.
- Select the Map Type tab, and verify Map as is set to Rectangle.
From the Topology ribbon, select the tool.
Figure 9.
Left-click and drag to create a line to split the surface.
Figure 10.
Left-click to create two fixed points.
Figure 11.
Figure 12.
In the modeling window, select the two surfaces and
click Mesh from the guide bar or
microdialog.
Figure 13.
Figure 14.
Set the edges density as shown in Figure 15.
Figure 15.
Figure 16.
- In the modeling window, select the right part.
- In the microdialog, verify Element type is set to Quads only.
- Select the Map Type tab, and set Map as to Triangle.
- Exit the tool.
Edit Mesh
Figure 17.
Left-click and drag to create lines to split the surface as shown in Figure 18.
Figure 18.
Figure 19.
In the modeling window, select the four surfaces and
microdialog.
Figure 20.
Figure 21.
Set the edges density as shown in Figure 22.
Figure 22.
Note: Your edge density may be slightly different. Adjust the edge density to obtain a regular mesh as shown in the images. -
Figure 23.
In the modeling window, select the surfaces highlighted
in Figure 24.
Figure 24.
In the modeling window, select the surface shown in
Figure 25.
Figure 25.
- Exit the tool.
