Select a Repository
- Click Personal to search for data within.
- Enter the values for the fields shown.
- オプション: Click the Display Options icon to select different views.
Click Open to open a file.
You are given the option to Get a local, read-only copy, or to Check-Out a copy for modification. In either case, the file will be copied to your active workspace, where it can be opened using the out-of-the-box Open feature.
