View a Material's Properties
Click the Show/Hide icon to view a material content’s
properties.
This toggles the property pane on and off. You can also double-click on a content to perform the same task.注: You can also preview the material’s stress-strain curve, if available.
- オプション:
Select the material content and click View Load Curve
from the コンテキストメニュー to view the stress-strain curve
for a material.
図 1.
注: You can overlay load curves by multi-selecting more than one material content before clicking the View Load Curve option.
