Set regional selection to by entity and no
regionid.
Using the props selector, select PWELD_500.
Click create.
Create the weighted component response.
In the responses= field, enter wcomp.
Below response type, select weighted comp.
Click loadsteps, then select all
loadsteps.
Change the weighting factors for SUBCASE200 and SUBCASE300 to
100.0.
This increases the influence of the two bending load cases versus the
torsion load case SUBCASE1, which remains at 1.0.
Click return.
Click create.
Click return to go back to the Optimization panel.
Create Design Constraints
Click the dconstraints panel.
In the constraint= field, enter volfrac.
Click response = and select Volfrac.
Check the box next to upper bound, then enter
0.3.
Click create.
Define the Objective Function
Click the objective panel.
Verify that min is selected.
Click response= and select wcomp.
Click create.
Click return twice to exit the Optimization panel.
最適化パラメータの修正
良好な結果を得るためには、一部の最適化パラメータを修正する必要があります。
opti controlサブパネルをクリックします。
DISCRT1D =の横のボックスにチェックマークを入れ、20.0と入力します。
1D要素のみについて密度法のペナルティー係数を増加したことで、離散的な結果が得られます。
OBJTOL =の横のボックスにチェックマークを入れ、1.e-5と入力します。
収束をチェックする目的のトレランスを低くします。
returnを2回クリックします。
Run the Optimization
From the Analysis page, click OptiStruct.
Click save as.
In the Save As dialog, specify location to write the
OptiStruct model file and enter
hut_opt for filename.
For OptiStruct input decks,
.fem is the recommended extension.
Click Save.
The input file field displays the filename and location specified in the
Save As dialog.
Set the export options toggle to all.
Set the run options toggle to optimization.
Set the memory options toggle to memory default.
Click OptiStruct to run the optimization.
The following message appears in the window at the completion of the
job:
OPTIMIZATION HAS CONVERGED.
FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
OptiStruct also reports error messages if any exist. The
file hut_opt.out can be opened in a
text editor to find details regarding any errors. This file is written to the
same directory as the .fem file.
