/IMPLICIT
Block Format Keyword This option allows different default values which are suitable for implicit calculations.
/IMPLICIT |
Changed Values
Option | Name | Description | New Value |
/DEF_SHELL | Iplas | Shell plane stress plasticity flag | 1 (iterative projection with three Newton iterations) |
Ishell | Shell formulation flag | 24 | |
Idril | Drilling degree of freedom stiffness flag | 1 | |
/DEF_SOLID | Isolid | Solid formulation flag | 14 |
/INTER/TYPE7 | Irem_i2 | Deactivate the secondary node flag | 1 |
- Some default values are different in certain options. See /SPMD (Obsolete) and /INTER/TYPE24.
