/MAT/LAW54 (PREDIT)
Block Format Keyword This law describes the predit material. This material law is only used with /PROP/TYPE36 (PREDIT).
| /MAT/LAW54/mat_ID/unit_ID or /MAT/PREDIT/mat_ID/unit_ID | |||||||||
| mat_title | |||||||||
| E | |||||||||
| fct_ID | A | B | N | Fscaleyld | |||||
| AY | AZ | BY | BZ | CX | |||||
| Dc | RC | ||||||||
Definition
| mat_ID | Material identifier (Integer, maximum 10 digits) |
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| mat_title | Material title (Character, maximum 100 characters) |
| Initial density (Real) |
| E | Young's modulus (Real) |
| Poisson's ratio (Real) |
| fct_ID | Hardening parameter function identifier (optional).
(Integer) |
| A | Hardening parameter yield coefficient
A. (Real) |
| B | Hardening parameter yield coefficient
B. (Real) |
| N | Hardening parameter yield coefficient
N. (Real) |
| Fscaleyld | Yield function scale factor. Default = 1.0 (Real) |
| AY | Y
shear coefficient of component
yield. (Real) |
| AZ | Z
yield. (Real) |
| BY | Y
moment coefficient of component
yield. (Real) |
| BZ | Z
yield. (Real) |
| CX | X
torsion coefficient of component
yield. (Real) |
| Dc | Critical damage (Real) |
| RC | Critical failure (Real) |
| Damage strain limit (Real) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW54/1/1
Steel
# RHO_I
7.8E-9
# E NU
21000 .3
# fct_ID A B N Fscale_yld
0 30 150 .9 0
# AY AZ BY BZ CX
.2 .2 .6 .6 0
# DC RC EPS_max
.8 2 .7
#ENDDATA
/END
- Scale factor is only used for fct_ID; otherwise /MAT/LAW36 (PLAS_TAB) is used.
