/MONVOL/AREA
Block Format Keyword Describes the monitored volume type AREA.
/MONVOL/AREA/monvol_ID/unit_ID
monvol_title
surf_IDex
Blank Format
Definition
monvol_ID Monitored volume identifier.
(Integer, maximum 10 digits)
unit_ID Optional unit identifier.
monvol_title Monitored volume title.
surf_IDex External surface identifier.
(Integer)
  1. surf_IDex must be defined using segments associated with 4-nodes or 3-nodes shell elements (possibly void elements), and not with /SURF/SEG.
  2. The volume must be closed and the normals must be oriented outwards.
