Shell
Remove material and create thin walls to generate a shelled part.
On the Geometry ribbon, select the
Shell tool.
Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:- Select
at the lower right corner of the
currently displayed tool. - Click and hold the currently displayed tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select
- Select one or more faces to remove.
In the microdialog, enter the desired thickness for the new shell.
Note: Click the Reverse Direction
icon to reverse the direction of the
shell. -
Click Apply
on the guide bar or microdialog to generate the shelled part.
Apply a Variable to Parameterize your model
Apply a variable to parameterize your model. Variables can be created on the fly from a tools where f(x) is present .
You can apply existing variables and add new ones via the microdialog in various tools.
In the tool’s microdialog, click the f(x) icon.
Figure 1. Example of a microdialog with a variable field
- In the dropdown menu, select Add Variable to create a new variable based on the dimension in the text field, or select the name of an existing variable.
- Click Apply to apply the variable to the construction feature.
Tip:
- You can also create a variable by entering a new name and expression in the
microdialog’s text field, for example:
Variable1=50 - In addition, you can also create a new variable based on an existing
variable, for example,
Variable2=Variable1*0.5.
