Test Altair Accelerator
You may wish to run a few simple jobs to confirm that the system is running properly.
Submit a simple job with the following commands:
% nc run sleep 30 Resources= linux Env = SNAPSHOT(vnc_logs/envjohn36829.csh) Command = sleep 30 Logfile = vnc_logs/20020602/105731.27873 JobId = 00002539 nc: message: Scheduled jobs: 1 Total estimated time: 0s
- The
JobId
in this example is 2539. The leading zeros are insignificant. - The environment used for the job execution is a snapshot of the current environment, stored in the file vnc_logs/envjohn36829.csh
- The default resource list for the job is
linux
which, in this example, is the platform from which the job was submitted. Later, you will learn how to control the resources assigned to a job.
Note: If the following dialog appears, see Qualify the Working Directory of Jobs.WARNING: The current directory '/export/scratch/john' may not be a valid directory path for all hosts in the cluster. EXPLANATION: If the job runs on a host other than the local node, and the current directory is not shared on that host, unpredictable results may occur. OPTIONS: (1) Continue. By choosing this option, you assert that the path is valid everywhere. If it is not, the job is likely to fail, because the remote host cannot reach the current directory. This option causes the creation of a flag file called .vnc which has the purpose of avoiding the repetition of this question for this directory and its subdirectories (2) Abort. Please ask your Accelerator administrator to change the equiv.tcl file to define the rules that give a logical name to the current directory. Please reply: [1,2] >
- The
Check the status of the job:
% nc list 00002539 Done sleep 10 % nc summary ...output omitted % nc info 2539 Id,User,Group 00002539,john,users Environment SNAPSHOT(vnc_logs/envjohn36829.csh) Directory ${HOMES}/john Command sleep 10 Status Running Host alpaca Resources linux QueueTime 0s RunningTime 9s
Check the output of the job, which in this case is empty, since it is the
output of
sleep
.% nc info -l 2539 Log file is: '${HOMES}/john/vnc_logs/20020602/105731.27873'
Rerun the job.
The first time Accelerator notices that the job is already Done (=VALID) so it does not run it again. The second time, the option -f forces Accelerator to rerun the job even if it is already Done.
% nc rerun 2539 nc rerun 00002539 nc: message: Not rerun: 00002539 % nc rerun -f 2539 nc: message: Job 00002539 is already VALID. nc: message: Scheduled jobs: 1 Total estimated time: 15s
Stop the running job. The job will fail.
% nc stop 2539
Forget the job:
% nc forget 2539 nc: message: Forgetting 1 jobs
Get a quick report:
% nc summary Accelerator Summary For User john TOTAL JOBS 105 Duration: 4m17s Failed 53 Queued 50 Idle 2 JOBS GROUP TOOL WAITING FOR... 50 pi vtclsh 'hpux#1 '
