Alternate Method of Sending Email
If SMTP is not available, a mailer program could be used instead.
Use a Mailer Program
The standard sendMail procedure checks the Method setting in the SMTP Configuration section of the vovnotifyd configuration web UI. The method may be set to PROGRAM in the web UI to allow you specify a custom mailer command.
