Write Localized Health Checks
The vovnotifyd command runs in the vovsh
binary,
so all the VTK API procedures are available to you.
The standard checks procedures are defined in the file $VOVDIR/tcl/vtcl/vovhealthlib.tcl.
The health check procedures are loaded by using a search path. They are loaded first from the file given above, then from $VOVDIR/local/vovhealthlib.tcl, and last from vovhealthlib.tcl in the vovnotifyd working directory. This permits redefining health check procedures on a site-wide or a project-specific basis.
doTestHealth
' such as
the system names; some platforms require on this convention. set HEALTHLIB_PRODUCT_MAP(doTestHealthYourProcedure) "nc"
The product names are those returned by the procedure vtk_product_get_info
-name
: nc, lm, ft, wa.
Ensure your procedures are robust and handle error conditions, such as catching all
exec{}
, open{}
and other procedures that may
fail.
