Job Status Triggers
The daemon vovtriggerd taps the event stream and executes commands that are based on selected events.
A typical application is updating an external SQL database when a job is completed.
Triggers are different from post-commands. Triggers are executed by vovtriggerd, which is normally run by the user who owns vovserver. The owner of the account that was used to start vovserver is the owner of vovserver. Post-commands are executed by the user who owns each job.
- Config file
- vnc.swd/vovtriggerd/config.tcl
- Sample config file
- $VOVDIR/etc/config/vovtriggerd/config.tcl
- Info file
- vnc.swd/vovtriggerd/info.tcl
Set Up vovtriggerd
- Create a subdirectory called vovtriggerd in the server configuration directory
- Create a configuration file called config.tcl with the main purpose of overriding the procedure called triggerCallBack
- Start the
daemon:
% mkdir `vovserverdir -p vovtriggerd` % cd `vovserverdir -p vovtriggerd` % mkdir autostart % cp $VOVDIR/etc/config/vovtriggerd/config.tcl . % vovdaemonmgr start vovtriggerd
The TRIGGER Property
The default trigger handler looks for the property TRIGGER
attached
to the object mentioned in the event. If the property exists, it is assumed to be
the name of a trigger procedure to be called. There are three arguments for the
trigger procedure: id
, subject
verb
- The trigger is stateless.
- The trigger is fast; it should complete within a few seconds.
TRIGGER
property: - Create a trigger call-back in the config.tcl file. In
the following example, it is named
trigShowJobEventCB
.# # This goes in PROJ.swd/vovtriggerd/config.tcl # proc trigShowJobEventCB { id subject verb } { puts "TrigShowJobEventCB: Just got the event $id $subject $verb" }
- Attach the property TRIGGER to jobs in the flow. Example:
% vovprop set -text 000123456 TRIGGER trigShowJobEventCB % vovprop set -text 000234567 TRIGGER trigShowJobEventCB
Trigger Events
- JOBID "JOB" "DISPATCH", when the job is dispatched to a tasker.
- JOBID "JOB" "ERROR", if the job fails.
- JOBID "JOB" "STOP", if the job succeeds.
Handling the OVERFLOW Event
If the vovtriggerd daemon receives an overflow event (the verb is
the string OVERFLOW
), the procedure
overflowCallBack is called with no arguments. The overflow
event is an indication of a buffer overflow inside the vovserver, which is typically caused by vovtriggerd being too slow in
processing the events. Depending on the situation, it may be useful to reinitialize
the trigger callbacks.
Example of Submission of Jobs with Triggers
The following example applies to Accelerator:
TRIGGER
property. Knowing
the name of the trigger callback routine to call is required. In the following
example, the name of the trigger callback is
updateDbCallBack.% nc run -P TRIGGER=updateDbCallBack sleep 10
# Example of updateDbCallBack
# This procedure is defined in *.swd/vovtriggerd/config.tcl
# Here we update a table called "mytable" based on the
# value of a property called MYPROP.
proc updateDbCallBack { jobid subject verb } {
switch $verb {
"STOP" - "ERROR" {
if [catch {set value [vtk_prop_get $jobid "MYPROP"]}] {
set value -1
set stmt "INSERT INTO mytable (id,value)"
append stmt " VALUES ( $jobid, $value)"
VovSQL::init
set handle [VovSQL::open]
VovSQL::query $handle $stmt
VovSQL::close $handle
