Upgrade Monitor Using the Online Database Method on Windows
Before starting, check if a license update if needed. Consider the following:
- If using a keyfile license, no license upgrade is needed.
- If using an RLM license, switch to an ALM license model
Note: If setting the environment variable is confusing,
just capture the folder path and location and make a note of it.
An overview of this process:
- Backup the current database.
- Upgrade the backup database.
- Switch the backup database as the production database.
Be sure to provide a meaningful folder name where the backup database resides. For
example:
set BACKUP=/big/DBBACKUP
For
example, /big/DB_14
Set LM_NAME to the Monitor project name and enable the shell.
% set LM_NAME=licmon % vovproject enable %LM_NAME% % vovserverdir -p % set SWD=%<_the_return_value_of_above_command%
For example:
% set SWD=C:\altair\swd\licmon.swd
Set more environment variables that will be used later. OLDVOVDIR is the value
of VOVDIR from the current software version, and NEWVOVDIR is the value of
VOVDIR from the new software version. For example:
% set OLDVOVDIR=C:\altair\lm_2210\win64 % set NEWVOVDIR=C:\altair\lm_2311\win64 (upgrade to v2023.1.1)
Record the location of the database for later removal.
vovdb_util showcfg
For example:
vovdb_util 08/14/2023 15:27:15: message: The VOV database configuration is: vovdb_util 08/14/2023 15:27:15: Host: localhost vovdb_util 08/14/2023 15:27:15: Port: 37204 vovdb_util 08/14/2023 15:27:15: Data Path: C:/altair/db/lm_2210_3 <<<<<<<<<<<<<< used this path in next step vovdb_util 08/14/2023 15:27:15: Status: ready vovdb_util 08/14/2023 15:27:15: AutoBackup: enable 0 period 604800 root {} startFrom 1 startTo 4 keep 3
Store the path in ORIGPATH.
% set ORIGPATH=C:/altair/db/lm_2210_3
Create PG 9.X database backup.
% set BACKUP=/big/DBBACKUP
For example:
% set BACKUP=C:\altair\DBBACKUP
Choose the location and set the BACKUP variable. This step runs at disk copy
speed. (Be sure to use a meaningful folder name.)
% vovdb_util backup %BACKUP%
For example:
vovdb_util backup C:\altair\DBBACKUP vovdb_util 08/14/2023 15:32:58: message: Backing up the database to 'C:\altair\DBBACKUP'... pg_basebackup: initiating base backup, waiting for checkpoint to complete pg_basebackup: checkpoint completed transaction log start point: 0/3000028 on timeline 1 pg_basebackup: starting background WAL receiver 39861/39861 kB (100%), 1/1 tablespace transaction log end point: 0/3007148 pg_basebackup: waiting for background process to finish streaming ... pg_basebackup: base backup completed vovdb_util 08/14/2023 15:33:06: message: Database backed up.
Source the vovinit.bat file to access the newly installed software:
% $NEWVOVDIR\bat\vovinit.bat
For example:
C:\altair\lm_2311\win64\bat\vovinit.bat
Verify the environment version:
% vovversion
For example:
% C:\Users\jlin>vovversion 2023.1.1
Export the PG 9.X database passwords using a version of the Accelerator
software (2023.1.0 or higher) that supports the
exportpasswords subcommand.
vovdb_util exportpasswords $SWD\PASSWORD_FILE
For example:
% vovdb_util exportpasswords C:\altair\licmon\licmon2.swd\PASSWORD_FILE vovdb_util 08/14/2023 16:18:48: message: Database passwords exported to: C:\altair\licmon\licmon2.swd\PASSWORD_FILE
Create a new Monitor converter project that will be used to convert the older
PG database to a version 14.4 database.
% set LM_CONVERTER=lm_temp_project (may skip) % $NEWVOVDIR\bat\vovinit.bat
For example:C:\altair\lm_2311\win64\bat\vovinit.bat
Steps 11 - 17 will target the Monitor $LM_CONVERTER project.
Configure the backed-up database for use in this new project.
% lmmgr start -name lm_temp_project -port any:1 -webport any:2 -roport 0 -inport any:3 -upport any:4
For example:lmmgr start -name lm_temp_project -port any:1 -webport any:2 -roport 0 -inport any:3 -upport any:4 lmmgr 08/14/2023 16:40:57: message: Starting Monitor instance lm_temp_project ...
Run the following commands:
% vovproject enable lm_temp_project % hostname % vovdb_util configure -noconfirm `hostname -s` %BACKUP%
For example:% vovdb_util configure -noconfirm sdc-win19csg-1 C:\altair\DBBACKUP
Check the path, which is the postgres bin\ folder of the
current release. For example:
C:\altair\lm_2210\win64\postgresql9_6\bin
Convert database PG 9.X to PG 14.4. This will operate at about 1/2 of disk-copy
speed.
% vovdb_util importpasswords $SWD/PASSWORD_FILE
For example:vovdb_util importpasswords C:\altair\licmon\licmon2.swd\PASSWORD_FILE
vovdb_util upgrade -sdb "C:\altair\DBBACKUP\dbdata9_6" -spgsw "C:\altair\lm_2210\win64\postgresql9_6\bin"
For example:vovdb_util upgrade -sdb C:\altair\DBBACKUP\dbdata9_6 -spgsw C:\altair\lm_2210\win64\postgresql9_6\bin vovdb_util 08/15/2023 10:38:19: message: sourceVer: 9_6 vovdb_util 08/15/2023 10:38:19: message: targetVer: 14_4 vovdb_util 08/15/2023 10:38:19: message: Preparing to upgrade VOV database to version 14.4: vovdb_util 08/15/2023 10:38:19: Source Dir: C:\altair\DBBACKUP\dbdata9_6 vovdb_util 08/15/2023 10:38:19: Version: 9.6 vovdb_util 08/15/2023 10:38:19: Target Dir: C:/altair/DBBACKUP/dbdata14_4 vovdb_util 08/15/2023 10:38:19: Version: 14.4 vovdb_util 08/15/2023 10:38:19: vovdb_util 08/15/2023 10:38:19: The upgrade process creates a copy of the database for use with the new version of PostgreSQL. There must be free disk space greater than the size of the current database. The original files will remain after the upgrade, but may be deleted at any time to reclaim disk space. vovdb_util 08/15/2023 10:38:19: Upgrade database (yes/no)? yes vovdb_util 08/15/2023 10:38:35: message: Proceeding with upgrade. vovdb_util 08/15/2023 10:38:35: message: Configuration of upgrade ...
After the database is converted, shut down the Monitor converter project:
% lmmgr stop -name $LM_CONVERTER -force
For example:lmmgr stop -name lm_temp_project
Wait for at least 5 seconds before shutting down the database. Then run:
% vovproject destroy -force $LM_CONVERTER
For example:vovproject destroy -force lm_temp_project vovproject 08/15/2023 10:55:22: message: Deleting c:/altair/licmon/lm_temp_project.swd/ vovproject 08/15/2023 10:55:22: message: Deleting registry entry C:/altair/lm_2311/win64/local/registry/jlin/lm_temp_project@sdc-win19csg-1 vovproject 08/15/2023 10:55:22: message: Deleting C:/altair/lm_2311/win64/local/registry/system-lm/lm_temp_project.reg
The remainder of the procedure will target the production Monitor project - $LM_NAME.
Shut down the Monitor project and disable the database so it does not come up
initially after restart:
Run:
% $OLDVOVDIR\bat\vovinit.bat
For example:C:\altair\lm_2210\win64\bat\vovinit.bat
Run:
% vovproject enable $LM_NAME
For example:vovproject enable licmon2
Run:
% vovdb_util stopdb
For example:vovdb_util stopdb vovdb_util 08/15/2023 11:15:09: message: Stopping database... vovdb_util 08/15/2023 11:15:10: message: Database stopped.
Run:
% lmmgr stop -name $LM_NAME -force
For example:lmmgr stop -name licmon2 -force lmmgr 08/15/2023 11:16:33: message: Stopping LicenseMonitor project licmon2... vovproject 08/15/2023 11:16:34: message: Checking privilege to stop project 'licmon2' vovproject 08/15/2023 11:16:34: message: Stopping all retracing vovstop 08/15/2023 11:16:34: msg-1: No retrace to stop vovproject 08/15/2023 11:16:34: message: Retracing stopped vovproject 08/15/2023 11:16:35: message: Stopping all daemons in licmon2 vovresourced STOPPING ... vovdbd STOPPING ... ...
Run:
Upgrade the production Monitor project with start and new Monitor software
version by running the following commands:
Wait for at least 5 seconds, and then initialize the new
directory:
Verify the version:
% vovversion
For example:vovversion 2023.1.1
Start a Monitor instance:
% lmmgr start -name $LM_NAME
For example:lmmgr start -name licmon2 lmmgr 08/15/2023 11:19:45: message: Starting Monitor instance licmon2 lmmgr 08/15/2023 11:19:45: message: Updating autostart/start_vovnotifyd.tcl... lmmgr 08/15/2023 11:19:45: message: Updating autostart/start_vovlmd.tcl... ...
Enable the Monitor project:
For example:vovproject enable licmon2 vovproject 08/15/2023 11:20:55: message: Enabling project 'licmon2'...
directory:
Configure the location of the PG 14.4 database, then start the database.
vovdb_util configure -reset -noconfirm `hostname -s` $BACKUP
For example:vovdb_util configure -reset -noconfirm sdc-win19csg-1 C:\altair\DBBACKUP vovdb_util 08/15/2023 11:24:02: message: Configuration saved.
Wait for a few seconds, then restart the database:
% vovdb_util startdb
For example:vovdb_util startdb vovdb_util 08/15/2023 11:25:03: message: Starting database... vovdb_util 08/15/2023 11:25:04: message: Checking user privileges vovdb_util 08/15/2023 11:25:04: message: User is not admin or service. vovdb_util 08/15/2023 11:25:04: message: Starting database vovdb_util 08/15/2023 11:25:04: message: LOG: starting PostgreSQL 14.4, compiled by Visual C++ build 1914, 64-bit vovdb_util 08/15/2023 11:25:04: message: LOG: listening on IPv6 address "::", port 37204 ...
- In the Monitor web portal, click Admin > System > Database Information. Scroll to the bottom of the page and verify the Engine Version displays 14.4.
Load checkouts that occurred since the time of the backup.
% lmmgr loaddb -v
For example:lmmgr loaddb -v lmmgr 08/15/2023 11:30:11: message: Loading all data files into the database... lmmgr 08/15/2023 11:30:12: message: Load all checkouts that come from sampling ...
- Remove the two extra database copies; for example backup db /big/DBBACKUP/pgdata9_6 and the original C:/altair/db/lm_2210_3/datadb9_6 project db.
