Plan the Installation
This section contains the system requirements and a set of preparation checklists that should be followed before installing the software. The checklists include a common section, followed by product specific sections.
Expected System Environment
- All participating hosts are networked.
- The host clocks are well-synchronized (e.g. via NTP).
- Naming services are functional and fast
- User/Group account names and UIDs are uniform on all machines
- Resolution of hostname works (DNS or NIS).
- Reverse DNS lookup works (get host name from IP address).
- There is a remote-shell capability for at least the product administrator's account to all participating machines. If not available, use the example .bat files as a guide to create a script, and place it in the appropriate directory. Example startup files are provided in $VOVDIR/etc/boot. Choose the one that best fits your scenario.
- There are networked file systems on which to place shared files, so that
they can be accessed from each machine, using a local path enabled by the
NFS. The shared files include:
- Installed Altair Accelerator software, including at least one branch that must be writable (the local directory).
- The Server Working Directory (.swd)
- The users' home directories.
- Work area for each project.
- Standard directories, binaries and libraries are available.
- /bin/sh, or /bin/bash on Linux
- /bin/csh, or /bin/tcsh
- /tmp exists
- /usr/tmp exists (not on Ubuntu by default)
- gcc libs are installed (libstdc++, libfcc_s)
System Configuration Hardware Guidelines
Use the following tables to provision your machines to support your projected usage.
- Accelerator and Allocator Hardware Guidelines
Resource Jobs 100,000 1,000,000 >1,000,000 CPU (x86, e.g. Intel Xeon) Dual Core Server Class Quad Core Server Class Quad Core Server Class Memory 2 GB 16 GB 32 GB Disk 5 GB 50 GB 200 GB Server Working Directory NFS or Local NFS or Local Local - Monitor Hardware Guidelines
Resource Checkouts 100,000 1,000,000 >1,000,000 CPU (x86, e.g. Intel Xeon) Dual Core Server Class Quad Core Server Class Quad Core Server Class Memory 1 GB 8 GB 16 GB Disk 5 GB 50 GB 200 GB Server Working Directory NFS or Local NFS or Local NFS or Local Database Local Disk Local Disk Local Disk - FlowTracer Hardware Guidelines
Resource Seat Licenses 1 10 100 >500 CPU (x86, e.g. Intel Xeon) Single/Dual Core Server Class Dual Core Server Class Dual Core Server Class Quad CoreServer Class Memory 1 GB 1 GB 8 GB 64 GB Disk 5 GB 50 GB 100 GB 200 GB - Accelerator Plus Hardware Guidelines
