Download the Software
After the pre-installation checklist is complete, you are ready to download the software and prepare the files in order to do the install.
Establish an Altair Accelerator Product Administrator User Account
It is recommended that you establish an Altair Accelerator Product Administrative user, or role account, on your computer. For example, define the user account accel_mgr, for installing and owning the Altair Accelerator software files.
You can share the Altair Accelerator Product Administrative user account with other tools. For example you can use Cadence's recommended user account cdsmgr to also be the Altair Accelerator Product Administrative account.
For evaluations, you can use your own personal account as the Altair Accelerator Product Administrator, and use it do the product install.
In the following sections, examples will be written as if you will perform the installation as user accel_mgr. For Accelerator production installations, one step in the procedure must be performed by the root user.
Create or Reuse a Temporary Download Staging Area
Create a staging area to hold the downloaded files. It must be different from the directory where you plan to install the Altair Accelerator software. The staging area may be removed after installation.
