Install Third Party Software: FlexNet Publisher Utilities: lmutil/lmstat
If you are installing FlowTracer, Accelerator or Monitor and need to either monitor licenses managed by FlexNet Publisher through Monitor, or use FlowTracer or Accelerator to execute applications that use FlexNet Publisher for license management, you will need to be able to execute the FlexNet Publisher lmutil utility, which is used to gather license utilization status.
This means you will need to install lmutil to provide support for this feature.
