Work. Pt. - U-f-N - Sinus application
Positioning and objective
This export allows the users to build a model of induction machine in Altair® Flux® 3D, which can be used to run steady state AC Magnetic application.
User inputs like line-line voltage, power supply frequency and speed are predefined to allow quick access into Flux® 2D environment for performing computations. The resulting model is full parameterized.
| Working point – U-f-N - Illustration |
The following section describes all the user inputs to initialize the exported model.
All these parameters can be modified in Flux® 3D environment if needed.
