ACU-T: 3100 Conjugate Heat Transfer in a Mixing Elbow
Prerequisites
Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up
Problem Description
The problem to be addressed in this tutorial is shown schematically in Figure 1. It consists of a mixing elbow made of stainless steel with water entering through two inlets with different velocities and at different temperatures. The geometry is symmetric about the XY midplane of the pipe, as shown in the figure.
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T3100_MixingElbowHeatTransfer.hm and click Open.
- Click .
Create a new directory named MixingElbow_HeatTransfer and navigate into this directory.
- Enter MixingElbow_HeatTransfer as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up the Problem
Figure 4.
The Setup dialog opens. -
Figure 5.
Click the Solver controls setting and verify that the
parameters are set as shown in the figure below.
Figure 6.
- Close the dialog and save the model.
Create a New Material Model
From the Flow ribbon, click the Material Library tool.
Figure 7.
The Material Library opens. - Under Settings, click Solid.
Click the My Materials tab then click
to
create a new solid.
A material creation dialog opens. -
Rename the material.
- In the top-left of the dialog, click Solid to edit the name.
- Type Steel and press Enter.
Change the Density value to 8030.
Figure 8.
- Click the Specific Heat tab.
Change the Specific heat value to 500.
Figure 9.
- Click the Conductivity tab.
Change the Conductivity value to 16.2.
Figure 10.
Exit the material creation dialog.
Figure 11.
- Exit the Material Library.
Assign Material Properties
Figure 12.
Select the outer pipe solid.
Figure 13.
- In the microdialog, click the drop-down menu next to Material and select Steel.
On the guide bar, click
to execute the command and remain in the
tool.
Next, select the inner pipe solid.
Figure 14.
- In the microdialog, click the drop-down menu next to Material and select Water.
to execute
Assign Flow and Thermal Boundary Conditions
Set Boundary Conditions for the Large Inlet
From the Flow ribbon, Profiled
tool group, click the Profiled Inlet tool.
Figure 15.
Click the face of the large inlet.
Figure 16.
- In the microdialog, enter a value of 0.4 for Average velocity and 295 for Temperature.
Rename the inlet.
- From the legend on the left side of the modeling window, double-click on Inlet
- Type Large_Inlet and press Enter.
tool.
Note: The number of inlets created appears in parenthesis on the top-right of the Profiled tool icon.
Set Boundary Conditions for the Small Inlet
Click the face of the small inlet.
Figure 17.
- In the microdialog, enter a value of 1.2 for Average velocity and 320 for Temperature.
Rename the inlet.
- Type Small_Inlet and press Enter.
to execute
Set Boundary Conditions for the Outlet
From the Flow ribbon, click the Outlet tool.
Figure 18.
Click the face of the outlet.
Figure 19.
In the microdialog, make sure both
Static pressure and Pressure loss factor are 0.
Figure 20.
to execute
Set Boundary Conditions for the Symmetry Planes
This geometry is symmetric about the XY midplane, and can therefore be modeled with half of the geometry. In order to take advantage of this, the midplane needs to be identified as a symmetry plane. The symmetry boundary condition enforces constraints such that the flow field from one side of the plane is a mirror image of that on the other side.
From the Flow ribbon, click the Symmetry tool.
Figure 21.
Click the face of the symmetry plane.
Figure 22.
In the microdialog, accept the
default symmetry conditions.
Figure 23.
tool.
Next, select the faces for the pipe wall symmetry.
Figure 24.
- In the microdialog, accept the default symmetry conditions.
Rename the boundary.
- From the legend on the left side of the modeling window, double-click on Symmetry 1
- Type Pipe_Symmetry and press Enter.
to execute
Set Boundary Conditions for the Outer Pipe Walls
From the Flow ribbon, click the No Slip tool.
Figure 25.
Click the faces of the outer pipe walls.
Figure 26.
to open
the temperature tab.
- Change the Convective heat coefficient value to 100.
Change the Convective heat resistance temperature value to
302.594.
Figure 27.
- From the legend on the left side of the modeling window, double-click on Wall
- Type Pipe_OuterWalls and press Enter.
to execute
- Save the database.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 28.
The Meshing Operations dialog opens.Note: If the model has not been validated, you are prompted to create the simulation model before running the batch mesh. - Check that the Average element size is 0.03606.
Accept all other default parameters.
Figure 29.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
Observe the refined mesh around the pipe walls.
Figure 30.
Run AcuSolve
Figure 31.
- Deactivate the Automatically define pressure reference option.
Leave the remaining options as default and click
Run to launch AcuSolve.
Figure 32.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: While AcuSolve is running, right-click on the AcuSolve job in the Run Status dialog and select View Log File to monitor the solution process.
Post-Process the Results with HM-CFD Post
- Once the solution is completed, navigate to the Post ribbon.
- From the menu bar, click .
Select the AcuSolve
.log file in your problem
directory to load the results for post-processing.
The solid and all the surfaces are loaded in the Post Browser.
- Isolate the Symmetry flow boundary in the Post Browser.
- Right-click on the Symmetry and select Edit.
- In the display properties microdialog, set the display to temperature and activate the Legend toggle.
Click
and set the Colormap Name to Rainbow
Uniform.
Figure 33.
Click
on the guide bar.
Figure 34.
- Isolate the Outlet flow boundary in the Post Browser.
Click the Right face on the View Cube to align the
model.
Figure 35.
Tip: If the orientation is not the standard, click the face again to re-align the model back to the standard orientation. - Right-click on Outlet and select Edit.
- Display the temperature.
Click
to reset the range.
Figure 36.
Click
on the guide bar.
Figure 37.
Summary
In this tutorial, you learned how to set up a conjugate heat transfer simulation using HyperMesh CFD and how to create a new material model. You launched AcuSolve directly from HyperMesh CFD to compute the solution and then post-processed the results using the Post ribbon.
