ACU-T: 3300 Modeling of a Heat Exchanger Component
This tutorial provides instructions for modeling a heat exchanger component using HyperMesh CFD. Prior to starting this tutorial, you should have already run through the introductory tutorial, ACU-T: 1000 Basic Flow Set Up, and have a basic understanding of HyperMesh CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperMesh CFD and AcuSolve.
Problem Description
Heat exchangers are devices used to facilitate heat exchange between two fluids that are at different temperatures. A typical heat exchanger device has two separate flows, the cross flow and tubular flow. Depending on the temperatures, heat can flow to or from one fluid to the other through the solids separating them. Since the heat exchanger geometry is quite complex with a large number of plates and pipes, it is not realistic to model the actual heat exchanger when performing system level simulations. In such scenarios, a simplified approach can be employed where only the effect of the heat exchanger on the cross flow is considered instead of modeling the actual heat exchanger. This is done using the heat exchanger component available in AcuSolve.
The heat exchanger component has two effects on the cross flow:
- Pressure drop which is calculated based on the friction parameters provided by the user.
- Heat addition or removal based on the coolant heat transfer parameters.
The Open File dialog opens. - Browse to the directory where you saved the model file. Select the HyperMesh file ACU-T3300_HeatExchanger.hm and click Open.
- Click .
Create a new directory named HeatExchanger and navigate into this directory.
- Enter HeatExchanger as the file name for the database, or choose any name of your preference.
Validate the Geometry
Set Up Flow
Figure 4.
The Setup dialog opens. -
- Verify that Time marching is set to Steady.
- Select Spalart-Allmaras as the Turbulence model.
- Activate the Heat transfer checkbox.
Figure 5.
- Close the dialog and save the model.
Assign Material Properties
Figure 6.
- Verify that the Air material has been assigned to all three volumes.
Click
on the guide bar to exit the tool.
Define the Heat Exchanger Component
From the Flow ribbon, click the arrow next to the
Domain tool set, then select
Heat Exchanger.
Figure 7.
Select the middle solid as the heat exchanger component volume.
Figure 8.
On the guide bar, click Inlet
then select the face shown below as the inlet of the heat exchanger
component.
Figure 9.
In the microdialog, enter the following
parameters:
Figure 10.
Figure 11.
to execute
- Save the model.
From the Flow ribbon, click the Constant tool.
Figure 12.
Click the inlet face highlighted in the figure below.
Figure 13.
In the microdialog, enter the following values for the
Momentum and Turbulence tabs.
Figure 14.
Figure 15.
to execute
Click the Outlet tool.
Figure 16.
Select the face highlighted in the figure below and then click
on the
guide bar.
Figure 17.
- Save the model.
Generate the Mesh
From the Mesh ribbon, click the
Volume tool.
Figure 18.
In the Meshing Operations dialog, set the Mesh growth rate
to 1.1 (if not set already).
Figure 19.
Click Mesh.
The Run Status dialog opens. Once the run is complete, the status is updated and you can close the dialog.Tip: Right-click on the mesh job and select View log file to view a summary of the meshing process.
- Save the model.
Run AcuSolve
Figure 20.
Leave the remaining options as default and click
Run to launch AcuSolve.
Figure 21.
Post-Process with the Plot Tool
In the Run Status dialog, right-click on the AcuSolve run.
Figure 22.
Select Plot time history to plot the residual and
solution ratios.
Figure 23.
Click
to create a new plot.
- Right-click User Defined under the Model panel to create a user defined function.
- In the Data Tree, expand Heat Exchanger Component Output then select coolant temperature.
- In the Name field, enter dT.
- In the Value field, type value=.
Under Parts, choose HX component then click
to insert the field as part of the value, as shown
below.
Figure 24.
- Type - at the end of the user defined function value.
In the Data Tree, select air temperature, then pick
HX component and click
to insert the field as part of the value.
Click
to add the user defined function.
Figure 25.
Click the x axis to switch to Time Steps.
Figure 26.
As shown in the plot above, the temperature rise is 43.3K.
Summary
In this tutorial, you successfully learned how to set up and solve a simulation involving a Heat Exchanger component using HyperMesh CFD. You started by opening the HyperMesh input file with the geometry and then defined the simulation parameters, the heat exchanger component, and the flow boundary conditions. Once the solution was computed, you defined a user-function in the Plot Manager in order to create a plot of the temperature rise across the heat exchanger volume.
