Jump to main content
HyperWorks
HyperWorks
2024.1
Index
  1. Home
  2. Multibody Modeling
  3. MotionView Ribbons
  4. Model
    Create and edit various model entities.
  5. Contacts
    Use the Contacts tool to specify the attributes of a contact force between two bodies.
  6. Best Practices for Running 3D Contact Models in MotionSolve
  • Welcome
  • What's New
    View new features for Altair HyperWorks 2024.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Developer
    The Developer ribbon contains tools for automation and customization.
  • Plot Data
  • Multibody Modeling
    • MotionView Overview
    • Model Browser
    • MotionView Ribbons
      • Assembly
        Create and edit systems, assemblies, and analyses, use wizards to build models quickly, create and edit belt/pullies, NLFE stabars, and NLFE springs, access the EDEM and Track Builder tools.
      • Geometry
        Create and edit points, bodies, lines (curve graphics), solids (graphics), markers and vectors, edit grounded/ungrounded bodies, create and edit rigid body groups, configure gravity, and select material properties.
      • Model
        • Joints
          Use the Joints tool to create and edit joints.
        • Motions
          Use the Motions tool to create motions and to edit the initial conditions, displacements, velocities, and acceleration of joints.
        • Couplers
          A Coupler entity defines an algebraic relationship between the degrees of freedom of two or three joints.
        • Gears
          Use the Gears tool to create a gear entity to relate the motion of two joints.
        • Advanced Joints
          Use the Advanced Joints tool to create and edit a set of special constraints called higher pair joints. Typically, these are constraints that involve a curve or surface on at least one of the two bodies.
        • Spring Dampers
          Use the Spring Dampers tool to edit the connectivity, properties, and initial conditions of springs and dampers.
        • Bushings
          Use the Bushings tool to create bushings and edit their connectivity, properties, and orientation rules.
        • Beams
          Use the Beams to create beams and edit their connectivity, properties, and orientations.
        • Polybeams
          Use the PolyBeams tool to create polybeams and edit their points and properties.
        • Forces
          Use the Forces tool to create forces and to edit the orientation and properties of forces.
        • FrequencyInputs
          Defines excitation inputs to a Frequency Response Analysis.
        • Contacts
          • Create Contacts Using the Contacts Tool
            The Contacts tool allows you to create a contact force between two bodies, a body and deformable curve or a deformable surface, or between two deformable curves or two deformable surfaces.
          • Edit Contacts
            Contact properties can be edited using the Entity Editor. Checks on graphics for suitability for contacts can also be performed.
          • Flex Contact
            MotionSolve supports contact between a flexible body and a rigid body or another flexible body. The method to add such a contact to a model is the same as a Rigid to Rigid Contact and uses the same panel as the contact between rigid bodies.
          • Contacts Post-Processing
            This section summarizes the post-processing capabilities that are available in MotionView, HyperView, and HyperGraph for contact models.
          • Best Practices for Running 3D Contact Models in MotionSolve
          • Geometry Cleanup for Contact Modeling
        • Contact Properties Editor
          The Contact Properties Editor macro enables you to edit multiple contact force entities in a model simultaneously.
        • General Constraints
          Use the General Constraints tool to create a generic expression-based constraint.
        • Fields
          Use the Fields tool to create a compliant connection between two bodies where stiffness or damping in one direction can be a function of displacement in another direction
        • Modal Forces
          The Modal Forces tool allows you to include a disturbed force on a flexible body that exists in the modal form in the flexible body H3D.
        • Surfaces
          Use the Surfaces tool to create and edit surfaces.
        • Deformable Curves
          Use the Curves tool to create and edit deformable curves.
        • Deformable Surfaces
          Use the Surfaces and Surfaces from FEM tools to create and edit deformable surfaces.
        • Spline2D/Curves
          Use the Spline2D/Curves tool to create and edit curves.
        • Spline3D
          The Spline3D panel allows you to add and edit three dimensional spline data.
        • Solver Variables
          Use the Variables tool to create solver variables that can be used to create an algebraic expression of state variables, as well as other solver variables. This can then be referenced in function expressions throughout the solver input file.
        • Datasets
          Use the DataSets tool to create and edit datasets comprised of object types, such as real, string, boolean, integer, and options.
        • Solver Arrays
          Use the Arrays tool to create solver arrays and set solver array data. Solver array types include X array, Y array, U array, IC array, Plant Input array, and Plant Output array.
        • Solver Strings
          Use the Strings tool to create a solver string and set solver string data. A solver string provides a string that can be accessed within the model, for example, to pass into a user subroutine.
        • Sensors
          Use the Sensors tool to sense an event during simulation and to define a response to that event
        • Control SISOs
          Use the SISOs tool to set control SISO data. This data can be used to add additional states to the mechanical system being modeled.
        • FMU
          Use the FMU tool to add a Functional Mock-up Unit and connect it to a multibody model.
        • Control State Equations
          Use the State Equations tool to create and set control state equation data.
        • Solver Differential Equations
          Use the Diff Equations tool to set solver differential equations. These equations can be used to add additional states to the mechanical system being modeled.
        • Orientation
          Use the Orientation tool to align an entity along a particular direction.
      • Analyze
        Create and edit outputs, create and edit templates, run the solver, view reports, access the Load Export utility, use the Optimization Wizard, open HyperStudy, utilize many pre-processing and post-processing capabilities with regards to flexible bodies (or flexbodies), run MS/EDEM cosimulation in batch mode, and generate H3D from EDEM.
    • MotionView CAD Interfacing
    • Flexible Bodies
      MotionView has many pre-processing and post-processing capabilities with regards to flexible bodies, or flexbodies, for multibody dynamics models.
    • Functional Mockup Unit (FMU)
      Add an FMU to the model or export a model as an FMU.
    • Vehicle Modeling
    • Tcl/Tk Reference Guide
      Reference material for the scripting interface which is a set of Tcl/Tk commands.
    • MDL Reference Guide
    • MotionSolve Reference Guide
    • Templex and Math Reference Guide
    • MotionView Python Reference Guide
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
See the Best Practices for Running 3D Contact Models in MotionSolve topic for additional information.
© 2024 Altair Engineering, Inc. All Rights Reserved.
