Leaf Spring Builder
The Leaf Spring Builder is used to model leaf springs, using rigid bodies, beams, and contact forces. It can information about the number of leaves, the leaf shapes, cross-sections, material properties, contact properties, shackle length (if your spring employs a shackle), nominal axle load and other information, to create an MDL system definition, which can be imported into a suspension or full vehicle model.
The Leaf Spring Builder saves the data entered to build a model and it can be imported in a leaf spring property file format. If needed, modify the leaf shapes, section properties, material properties or other components of a leaf spring model, by opening the leaf property file in the Leaf Spring Builder, make the modifications and then build a new leaf spring system definition.
Leaf Spring Builder - Toolbar
- File Menu
- The following options are available in the File Menu:
- New
- Opens a new session in the Leaf Spring Builder.
- Open
- Opens an existing .lpf file.
- Save
- Saves the built leaf property file in the required location.
Figure 2. File Menu Options
- Tools
- Upon selecting the Check Model option, the Leaf
Builder Message window opens and checks for any errors in the built leaf model.
Figure 3. Tools Menu Options
- Examples
- Examples of pre-built leaf spring models are displayed in the list.
Figure 4. Examples Menu List
Coordinate System Convention
- X-axis: Defines the longitudinal axis of the leaf spring.
- Y-axis: Defines the lateral axis of the leaf spring.
- Z-axis: Defines the vertical axis of the leaf spring.
- Origin (0,0,0) will be at the center of the top most leaf.
- X and Z data should cover the longitudinal and vertical span of a leaf spring.
- It cannot be changed.
Leaf Spring Components
The following sections explain more about each Leaf Spring Component in detail.
