Anti-Dive/Lift and Brake Dive/Lift
Request Number: 80000240
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left Front Anti-Dive or Left Rear Anti-Lift | % | The resistance to diving in a front suspension or resistance to lifting in a
                  rear suspension due to suspension geometry during braking. In a suspension with
                  100% anti-dive/lift the moment about the side view instant center due to weight
                  transfer is exactly offset by the moment about the side view instant center due to
                  the braking force. See the following equations:
| F3 | RESULT(3) | Right Front Anti-Dive or Right Rear Anti-Lift | % | See F2/RESULT(2) (above) for explanation and equations. |
| F4 | RESULT(4) | Average Front Anti-Dive or Rear Anti-Lift | % | The mean of the left and right front anti-drive or left and right rear anti-lift. |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left Front Dive or Left Rear Lift | mm/g | The front suspension dive or rear suspension lift during braking or:
| F7 | RESULT(7) | Right Front Dive or Right Rear Lift | mm/g | The front suspension dive or rear suspension lift during braking or:
| F8 | RESULT(8) | Average Front Dive or Rear Lift | mm/g | The mean of the left and right front drive or left and right rear lift. |
