Longitudinal Force Deflection
Request Number: 80000110
| .plt File | .mr, .abf File | Component | Unit | Comment |
| F1 | RESULT(1) | Not Used | Not Used | Not Used |
| F2 | RESULT(2) | Left WC Longitudinal Force Deflection | mm/kN | The left wheel center longitudinal deflection due to parallel longitudinal
                  forces applied to the left and right wheel centers or: (C(1,1) + C(1,7))*1000 |
| F3 | RESULT(3) | Right WC Longitudinal Force Deflection | The right wheel center longitudinal deflection due to parallel longitudinal
                  forces applied to the left and right wheel centers or: (C(7,1) + C(7,7))*1000 | |
| F4 | RESULT(4) | Average WC Longitudinal Force Deflection | The mean of the left and right wheel center longitudinal force deflection. | |
| F5 | RESULT(5) | Not Used | Not Used | Not Used |
| F6 | RESULT(6) | Left TP Longitudinal Force Deflection | The left wheel center longitudinal deflection due to parallel longitudinal
                  forces applied to the left and right tire patches or: (C(1,1) + C(1,7) - slr*(C(1,5) + C(1,11)))*1000 | |
| F7 | RESULT(7) | Right TP Longitudinal Force Deflection | The right wheel center longitudinal deflection due to parallel longitudinal
                  forces applied to the left and right tire patches or: (C(7,1) + C(7,7) - slr*(C(7,5) + C(7,11)))*1000 | |
| F8 | RESULT(8) | Average TP Longitudinal Force Deflection | The mean of the left and right tire patch longitudinal force deflection. |
