| F1 | RESULT(1) | Not Used | Not Used | Not Used |
                | F2 | RESULT(2) | Left Front Anti-Lift or Left Rear Anti-Squat | % | The resistance to lifting in a front suspension or resistance to squatting in
                  a rear suspension due to suspension geometry during acceleration. In a suspension
                  with 100% anti-lift/squat the moment about the side view instant center due to
                  weight transfer is exactly offset by the moment about the side view instant center
                  due to the acceleration force. See the following equations:
                      Front Suspensions Live Axlesacx = -(front drive ratio)/2dtwt = slr*abs(2*acx)/(diff
                          ratio)/trackaczleft = -(cg height)/2/(wheel base) -
                          dtwtaczright= -(cg height)/2/(wheel base) +
                          dtwtOrientation A:dzfleft =
                          acx*(C(3,1)-slr*C(3,5))+acx*(C(3,7)-slr*C(3,11))dzfright =
                          acx*(C(9,1)-slr*C(9,5))+acx*(C(9,7)-slr*C(9,11))Orientation B:dzfleft =
                          acx*(-C(3,1)+slr*C(3,5))+acx*(-C(3,7)+slr*C(3,11))dzfright =
                          acx*(-C(9,1)+slr*C(9,5))+acx*(-C(9,7)+slr*C(9,11))dzwleft = aczleft*C(3,3) +
                          aczright*C(3,9)dzwright = aczleft*C(9,3) +
                          aczright*C(9,9)left anti-lift =
                        -100*dzfleft/dzwleftright anti-lift =
                        -100*dzfleft/dzwleftFront Suspensions Fixed Differentialsacx = -(front drive ratio)/2aczleft = -(cg height)/2/(wheel
                        base)aczright= -(cg height)/2/(wheel
                        base)Orientation A:dzfleft = acx*C(3,1)+acx*C(3,7)dzfright = acx*C(9,1)+acx*C(9,7)Orientation B:dzfleft = -acx*C(3,1)-acx*C(3,7)dzfright = -acx*C(9,1)-acx*C(9,7)dzwleft = aczleft*C(3,3) +
                        -100*dzfleft/dzwleftRear Suspensions Live Axlesacx = -(1 - front drive ratio)/2dtwt = slr*abs(2*acx)/(diff
                          ratio)/trackaczleft = (cg height)/2/(wheel base) -
                          dtwtaczright= (cg height)/2/(wheel base) +
                        -100*dzfleft/dzwleftRear Suspensions Fixed Differentialsacx = -(1 - front drive ratio)/2aczleft = (cg height)/2/(wheel
                        base)aczright = (cg height)/2/(wheel
                        -100*dzfleft/dzwleft |
                | F3 | RESULT(3) | Right Front Anti-Lift or Right Rear Anti-Squat | % | See F2/RESULT(2) (above) for explanation and equations. |
                | F3 | RESULT(3) | Average Front Anti-Lift or Rear Anti-Squat | % | The mean of the left and right front anti-lift or left and right rear
                  anti-squat. |
                | F4 | RESULT(4) | Left Front Lift or  Left Rear Squat | mm/g | The front suspension lift or rear suspension squat during acceleration or:
                      Front Suspensionsleft lift = -(dzfleft+dzwleft+aczleft/(tire
                          stiffness))*weightRear Suspensionsleft squat = (dzfleft+dzwleft+aczleft/(tire
                          stiffness))*weight |
                | F5 | RESULT(5) | Right Front Lift or Right Rear Squat | mm/g | The front suspension lift or rear suspension squat during acceleration or:
                      Front Suspensionsright lift = -(dzfright+dzwright+aczright/(tire
                          stiffness))*weightRear Suspensionsright squat = (dzfright+dzwright+aczright/(tire
                | F6 | RESULT(6) | Average Front Lift or Rear Squat | mm/g | The mean of the left and right front lift or left and right rear
                  squat. |
