2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Remove the first marker from the dynamic measure.
Remove the second marker from the dynamic measure.
Remove the first marker from the static measure.
Remove the second marker from the static measure.
Gets a handle to an hwIFont interface for the font of the measure.
Gets the measure line color.
Gets the format used for displaying values on the measure.
Gets the Length of the master measure in the selected unit.
Gets the name of the measure.
Gets the first marker ID of the dynamic measure line.
Gets the second marker ID of the dynamic measure line.
Gets the value of the flag denoting whether or not the master measure is the transient type.
Gets Length of the master measure in screen pixels.
Gets the number of decimal places displayed for values on the measure.
Gets the value of the flag denoting whether or not the measure line should be drawn on the video.
Gets the value of the flag denoting whether or not the X, Y values of the end points should be shown on the measure.
Gets the value of the flag denoting whether or not the magnitude annotation should be shown on the measure.
Gets the value of the flag denoting whether or not the name of the measure should be shown on the video.
Gets the value of the flag denoting whether or not the X values of the endpoints and the X value difference should be shown on the measure.
Gets the value of the flag denoting whether or not the Y values of the endpoints and the Y value difference should be shown on the measure.
Gets the time step of the transient measure.
Gets the type of the measure.
Gets the unit type used by the master measure.
Sets the color of the measure line.
Sets the format used for displaying values on the measure.
Sets the length of the master measure in the selected unit.
Sets the name of the measure.
Sets the number of decimal places displayed for values on the measure.
Sets the value of the flag denoting whether or not the measure line will be drawn on the video.
Sets the value of the flag denoting whether or not the X, Y values of the end points will be shown on the measure.
Sets the value of the flag denoting whether or not the magnitude of the measure will be shown on the video.
Sets the value of the flag denoting whether or not the name of the measure will be shown on the video.
Sets the value of the flag denoting whether or not the X values and X value difference of the end points will be shown on the measure.
Sets the value of the flag denoting whether or not the Y values and Y value difference of the end points will be shown on the measure.
Sets the time step of the transient measure.
Sets the unit type of the master measure.
Use the Task Manager to load an XML file that defines tasks and their attributes.
