2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the frame rate used when exporting AVI files.
Gets the palette used when exporting AVI files.
Gets the relative size (in percent) used when exporting AVI files.
Sets the frame rate used when exporting AVI files.
Sets the palette used when exporting AVI files.
Sets the relative image size (in percent) used when exporting AVI files.
Use the Task Manager to load an XML file that defines tasks and their attributes.
