2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Adds a message to the Message Log.
Clears away all messages on the Message Log and closes the Message Log window.
Configures the Message Log remain undisplayed when a new message is added.
Configures the Message Log to be displayed when a new message is added.
Gets the maximum number of messages that can be stored in the Message Log.
Gets the text within the Message Log.
Hides the Message Log.
Finds if the Message Log will be displayed when a new message is added.
Finds if the Message Log is visible or hidden.
Changes the maximum number of messages that can be stored in the Message Log.
Use the Task Manager to load an XML file that defines tasks and their attributes.
