2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Returns the class name as a string.
Returns the super class name as a string.
Tests if the given class name is the class or a descendant of the named class.
Used to free this interface object.
Casts the supplied object to an hwIObject.
Use the Task Manager to load an XML file that defines tasks and their attributes.
