2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Returns the aspect ratio string.
Gets the graphics area bottom offset for publishing.
Gets graphics area left offset of Publishing.
Gets the graphics area right offset for publishing.
Gets the graphics area top offset for publishing.
Gets title's left offset for publishing.
Gets the title's top offset for publishing.
Returns the master dimension.
Returns true or false.
Gets the image height for publishing.
Gets the picture resolution for publishing.
Gets the image width for publishing.
Gets the PowerPoint file's master path.
Returns the PowerPoint scale factor.
Gets whether or not to sync the table color formatting.
Returns the title attribute for publishing.
Gets the title font name for publishing.
Gets the title font size for publishing.
Gets the title font slant for publishing.
Gets the font weight for publishing.
Updates the resolution with the selected aspect ratio string.
Sets the bottom offset of the graphics area.
Sets the left offset of the graphics area.
Sets the right offset of the graphics area.
Sets the graphics area for the top offset.
Sets the title's left offset.
Sets the title distance from the top.
Allows you to set whether or not to publish one window per page.
Sets the graphics height.
Sets the picture resolution to the fixed/graphics or scaling factor option.
Sets the graphics width.
Allows you to set the PowerPoint master file's path.
Sets whether or not to sync color formatting.
Sets the title attribute to either text or master.
Allows to set the title font to different fonts
Sets the size for title font.
Sets the title font slant to slant or italics.
Sets title font weight to bold or normal.
Use the Task Manager to load an XML file that defines tasks and their attributes.
