2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the ID of a layer.
Gets the name of a layer.
Gets a list of the pages that reference this layer.
Gets the visibility of a layer.
Sets the value of a given attribute for a layer.
Sets the name of a layer.
Sets the visibility of a layer.
Use the Task Manager to load an XML file that defines tasks and their attributes.
