2024
The Aerospace menu provides you with access to various aerospace tools.
View new features for Altair HyperWorks 2024.
This tool allows you to have the same system defined in both HyperView and HyperMesh.
The NVH menu provides you with access to various NVH utilities.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
The Developer ribbon contains tools for automation and customization.
