Create Connector Responses
Use the Connector tool to create connector responses. The resulting response is the number of realized connections in the entire model or in selected connectors.
Restriction: Connector responses are not available for Generative Design
explorations.
From the Design Explorer ribbon, click the Connector
tool.
- Optional:
Select connectors.
If no connectors are selected, then the response will be the number of realized connections in the entire model.
On the guide bar, click
to
create the response.
