Generic responses can be created two ways, by specifying a solver result file
containing the desired response or by specifying a session file containing desired response
evaluations.
Create a generic response from
any solver result file HyperMesh can read.
Restriction: Generic responses are not available for Generative Design
explorations.
From the Design Explorer ribbon, click next to Responses and
select Generic Response.
In the Result File tab of the Create Generic Response
dialog, enter a name in the Response Name field.
In the Result File field, click to browse for a result
file.
The dialog fields automatically populate based on the result file
selection.
Review and edit additional response options.
Optional: Select the Objective or
Constraint check box to create the corresponding goal
when the response is created.
Optional: Click Plot to view a preview of the response before
creation.
Click Create Response.
Create Generic Response from a Session File
Create a generic response from a session file.
Note: Where the responses are defined in a table client, the following format is used:
Required entries
Cell A1 must be labeled DE Responses
Column A: response name
Column B: response evaluation
Optional entries
Column C: objective (min/max) or constraint operator
Column D: constraint value
In the Create Generic Response dialog, click the
Session File tab.
In the Session File field, click to browse for a session
file.
