Access the Mount Optimization Utility
First, register the NVH preferences file and load the NVH Utilities.
From the File menu, click .
The Preferences dialog is displayed.
The NVH menu is added to the menu bar.
From the Preferences dialog, select NVH-Utilities and
click Load.
From the NVH menu, select Mount Optimization.
An NVH-Utilities tab is added to the browser.Note: This browser tab contains the Load tab. It also contains icons for other utilities, such as modal participation and order cut analysis. Select an icon to toggle between the utilities.
- To close the NVH-Utilities tab, click the X in the upper right corner of the dialog.
