The AMF header is essentially the same as a Microsoft AVI header. However, AMF file
readers, such as HyperGraph, use partial information
from the header block. Note the following portion of a HEX dump from an AMF file,
with the portions used by an AMF reader highlighted:Figure 1.
Light Green
Number of frames stored least significant byte (LSB) first.
Royal Blue
Width of the image in pixels stored LSB first.
Dark Pink
Height of the image in pixels stored LSB first.
Cyan
Byte offset stored as a long integer (4 bytes) and stored LSB
first.
Red
Four Character Code (4CC), which identifies compression type.
