Loadstep ID Management in HyperView
There are four result files in this example, and we will assume that result file "A" has
loadstep IDs 101, 102, and 103, result file “B” has loadstep IDs 101, 102, and 103, result
file “C” has loadstep IDs 1, 2, and 3, and result file “D” has loadstep IDs 4, 101, and
102.
- Result file “A” is loaded into HyperView.The loadstep IDs will be:
- 101
- 102
- 103
- Result file “B” is loaded into HyperView.The loadstep IDs will be:
- 101
- 102
- 103
- 104
- 105
- 106
- Result file “C” is loaded into HyperView.The loadstep IDs will be:
- 1
- 2
- 3
- 101
- 102
- 103
- 104
- 105
- 106
- Result file “D” is loaded into HyperView.The loadstep IDs will be:
- 1
- 2
- 3
- 4
- 101
- 102
- 103
- 104
- 105
- 106
- 107
- 108
Creating Derived Subcases
It is important to understand the HyperView numbering policy (shown above) when creating configuration files for a derived loadstep. The order in which the result files are added into a HyperView session is important, especially if the various result files have the same loadstep IDs. Follow the steps outlined below in order to see a brief example of how the numbering policy works in HyperView.
Step 1:
- Start a HyperView session.
- Load result file “A” and result file “B”.
- Create a Linear Superposition loadstep using all of the available loadsteps: 101, 102,
103, 104, 105, and 106 (with scale factors of 1, 2, 3, 4, 5, and 6, respectively).
The loadsteps coming from result file “A” will have scale factors of 1, 2, and 3. The loadsteps coming from result file “B” will have scale factors of 4, 5, and 6.
- Save a configuration file.
Step 2:
- Now change the order of loading the result file, load result file “B” first this time and then load result file “A”.
- Loadsteps 101, 102, and 103 are coming from result file “B”, and 104, 105, and 106 are coming from result file “A”.
- Next, load the configuration file previously created in Step 1.
Observe that the applied scale factors are applied interchangeably.
