Review and Edit a Measure
Change the Display Options of a Measure
- Set the entity selector to Measures and select a measure.
Alternatively, from the Measure table dialog, select a measure and right-click to Edit.
This will display the Entity Editor dialog.
Tip: You can also select the measure in the Results Browser and use the docked Entity Editor located at the bottom. - Use the Display section of the Entity Editor to change the
following:
- Select a new font type/style/size.
- Choose Measure text display options in the modeling window.
- Change color (this can also be done from the color column in the measure table or measure list in the browser).
Delete a Measure
Delete. Tip: You can also select the measure in the Results Browser and right-click to Delete.
Change Global Display Options
You can control the display for all measure types using the Display Options.
Tip: You can also select the measure in the Results Browser and use the docked Entity Editor located at the bottom. - Use the Global section of the Entity Editor to change the
following:
Option Description Transparency Activate the check box to remove the color from the measure group box and make it transparent against the window. Auto-hide Activate the check box to hide the measure group box when the selected entities are not visible on the screen. Prefix Activate the check box to show the prefixes for the measure readouts (for example, "Value ="). Format Select either the Fixed or Scientific format for the measure labels. Precision Set the numeric precision from 0 to 10 decimal points. Angle Select either Degrees or Radians as the unit format used to display the angle.
