Add a Field Name to a Note
From the Annotate tools, click the Notes tool.
- Double-click on the note to edited.
Use the in-place editor to type in your expression or use the "+" drop-down
menu to insert commonly used fields.
Figure 2. Note in-place editor
- For advanced fields, click the top right button in the editor to open the floating Entity Editor dialog.
Click on the Text field to open the Note text
editor.
Figure 3. Note text editor
- Select the appropriate field along with numeric format and precision, wherever applicable, to insert the field.
- Click Apply or OK to confirm your changes.
