Access Model Correlation in HyperView
From the File Menu, click .
The Preferences dialog is displayed.
- Select NVH-Utilities from the Preferences dialog.
Click Load.
The NVH menu is added and displayed on the menu bar.
From the NVH menu, select Model Correlation.
An NVH-Utilities tab is added to the browser.Note: This browser tab contains the Load tab. It also contains icons for other utilities, such as modal participation and order cut analysis. Select an icon to toggle between the utilities.
- To close the NVH-Utilities tab, click on the X in the upper right corner of the dialog.
