Jump to main content
HyperWorks
HyperWorks
2024
Index
  1. Home
  2. Results Data
  3. Results Data in HyperView
  4. Create Entities
  5. Create Derived Results
    The Expression Builder is a graphical user interface which allows user-defined data type expressions to be authored directly within HyperView.
  6. Result Math
    A result manipulation library that enables user-defined data types to be added to a result, and transitions complex data manipulation tasks from HyperView to a reusable, modifiable set of libraries that focus solely on result processing tasks.
  7. Result Math Reference Guide
  • Welcome
  • What's New
    View new features for Altair HyperWorks 2024.
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
    • Results Data in HyperMesh
    • Results Data in HyperView
      • Working with Models
      • Animate and Visualize Results
      • Create Entities
        • Create Derived Results
          • Output Parameters
            The output parameters section of the Expression Builder allows you to define the data type label and output for the newly created result.
          • Operators
            The list of available operators is controlled by the template file selected when loading a model and result, and it can be modified by adding or removing <using /> statements in the template.
          • Table Selection
            Once an operator is selected, tables must be selected to form the input.
          • Default Arguments
          • Constant Value Arguments
            When an argument is passed as a constant, it is converted to a constant value table by the Expression Builder.
          • Additional Resources
            Additional resources can be attached to the analysis for the purpose of adding new tables.
          • Authoring Expressions
            The Expression Builder uses a Templex-like syntax to author Result Math XML commands.
          • Result Math
            • Results Browser
            • Result Math Templates
              Various Result Math templates are available whenever a model/result pair is loaded into HyperView.
            • Creating New Datatypes
            • Operator Library Reference
              Result Math operators are contained within a set of related functions organized by category or industry vertical known as libraries.
            • Error Handling
            • Known Limitations
            • Result Math Reference Guide
        • Derived Load Cases
          The Loadcase tool allows you to create a derived load case from other load cases, or from a combination of other load cases and simulation steps.
        • Systems
          Create your own user defined coordinate systems or select result coordinate systems.
        • FLD
          Use the FLD tool a plot a Forming Limit Diagram (FLD) based on a material Forming Limit Curve (FLC) and the major and minor strain output results of a forming simulation.
        • CFD Post-Processing
          HyperView offers CFD post-processing capabilities for a large class of industrial applications.
        • Tracking
          Use the Tracking tool to track any entity during animation.
        • Sets
          Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
      • Query Data
      • Annotate Models
      • Transform Models
      • Overlay Images/Videos
      • Rendering Models
      • Additional Tools for Post-Processing
      • Profiles
      • Preferences Dialog
      • Display/Visualization Options
      • HyperView - MultiCore
        A new workflow emphasizing the multicore profile for standard crash post processing use cases.
  • Developer
    The Developer ribbon contains tools for automation and customization.
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
See the Result Math Reference Guide for additional information.
© 2024 Altair Engineering, Inc. All Rights Reserved.
