Export a Set
- From the Create tools, select .
- From the Set panel, select a set/group.
Click Export.
Note: You can also access the Export Sets dialog by selecting the option from the Tools menu.The Export Sets dialog is displayed.
- Select a file type (HyperView set definition file, Patran session file, Nastran set file, or OptiStruct set file) from the Select format drop-down menu.
- Under File name, click the open folder icon and select a destination folder.
- Enter a file name and click Save.
- Optional: Activate the Export selected sets option to export only selected sets in the panel.
Click OK in the Export Sets dialog.
The exported file is saved as a text file.Note: When exporting, HyperView will automatically export the ID ranges contained in the set instead of writing out the individual IDs.
