2024
Use the Tracing tool to trace system, component, and node entities during animation.
View new features for Altair HyperWorks 2024.
Use the Notes tool to label items, describe trends, and relate additional information.
A new workflow emphasizing the multicore profile for standard crash post processing use cases.
The Developer ribbon contains tools for automation and customization.
To delete the current reference line.
