Create Summary Tables
Create summary tables containing free-body forces and moments for one or multiple sections and for one or multiple loadcases.
Create Displacement/Rotation Summary Table
Use the FBD Manager tool to create summary tables with free-body displacements and rotations for the selected free-body sections and loadcases.
From the Post ribbon, select the FBD Manager tool from
the Plot group.
The FBD Manager dialog opens. - Select free-body sections.
- Select loadcases to consider.
- From the Options tab, select Free Body System or Global System for Resolve In.
- Define the Tolerance.
- From the Export tab, select Displacement/Rotation.
Click
The summary table is created.Tip: To write displacements in Analysis System, use a Mesh based free-body section and set Resolved-In to Analysis System. Then select Free Body System.The table shows the proper system and ID per node ID.
Restriction: Plane based section project displacement components in plane local system so results appear as FreeBody System for Resolve in, but there is no system ID written in the table.
Create Summary Table with Force and Moment
Use the FBD Manager tool to create summary tables with free-body forces and moments for one or multiple sections and loadcases. The summary table, and summary table summation points, can be used to create Potato/VMT plots.
the Plot group.
- From the Export tab, select Free body forces/moments or Grid point forces/moments.
- Optional: If Grid point forces/moments is selected, select the relevant contributions to take into account.
Select
and select the summary table type.
Summary table types:- Summary Table: shows all forces and moments for nodes and summation points.
- Summary Table Summation Points: shows all forces and moments at summation points only.
- Min/Max Table: shows the higher and lower values of forces and moments at summation points along the selected loadcases.
Create Summary Table and .fbd File
Use the Potato/VMT tool to create a summary table and .fbd file that will be imported by HyperGraph 2D.
the Plot group.
Figure 3.
- From the Options tab, select a working directory where the .fbd file will be written.
- For Resolve In, select Free Body System or Global System.
Click
Export a .fbd file.
Click
and select Potato/VMT Plot GUI.
- In the Potato Plot - VMT Plot File Preparation dialog, select the source table.
- Click Create.
Click
