Fit Airbag to Housing/Container
Use the Housing tool to fit the airbag to housing/container.
From the Airbag ribbon, click the
Housing tool.
On the guide bar, click
- Folds Directory: The location where the results of the run are written.
- On the guide bar, click Components.
- Select the airbag components.
Set advanced selections as necessary by clicking
on the guide bar.
- On the guide bar, click Container.
Select the target container of the airbag.
Once completed, a copy of the container appears. You have to position it in order to have it fully enclosing the airbag without any intersection.
- On the guide bar, click Export to export the pre-simulation model.
At the end of the pre-simulation run, click the satellite icon
to load the new positions from the resulting .h3d file.
