Flatten the Airbag
Use the Flatten tool to flatten the airbag.
Before performing a given fold, it may be better to flatten the airbag, like a real operator would do with a real airbag.
From the Airbag ribbon, click the
Flatten tool.
On the guide bar, click .
- Folds Directory: The location where the results of the run are written.
- On the guide bar, click Components.
- Select the airbag components.
- Set advanced selections as necessary by clicking on the guide bar.
- On the guide bar, click Export to generate the pre-simulation deck.
- At the end of the pre-simulation run, click the satellite icon to load the new positions from the resulting .h3d file.
