Read .h3d Node Positions
Use the Read Positions tool to read .h3d node positions.
For every task, with the exception of creating a table, once the solver run is finished you will import the new node positions, and in the stitching the new connectivity, from the .h3d file generated.
Restriction: This tool is designed for working with models in the kg, mm, ms
unit system.
From the Airbag ribbon, click the satellite
icon
that appears when you hover over the tool.
- Enter a File name (.h3d file) and click Open.
