Property Summary
The Property Summary module generates summary of entire model properties, by its name, type and ID.
  • Property Info with Type and ID
  • Properties browser view
  • Shell Thickness Summary
  1. From the Report Ribbon, Add Modules tool group, click and select Property Summary module.
    Or
    Right-click at the Report or Chapter level and select Report/Chapter > Add > Modules > Model Info > Property Summary.
  2. Below are the properties associated with the Property Summary module.
    Name
    The name for the Property Summary.
    Model
    Provide the location of the model in the list of HyperMesh windows in the session.
    Table of all properties by its Name, Type and ID.
    Replicate Properties browser view
    The currently displayed tabular data in the Properties browser in HM will be copied into a table.
    This option generates the entire model Shell-based property summary based on Shell thickness. It creates a distribution summary as Thickness, Material ID and Property ID.
  3. Once executed, a table output for Shell Thickness Summary is generated as follows:
    Info Model- Text Note. This is created only in Document or HTML reports.
    Model Thickness in mm- Image file.
    Figure 3.
    Model Material and Property IDs and plies 0°, 45°, -45°, 90° - Table.
    Figure 4.
  4. Once executed, a table output for Property Summary is generated.
    Figure 5. Property Info with Type and ID.
