- Category and Folder View
Use the Category view to view the library contents according to category. Use the Folder view to view the library contents according to what folders they reside in.
- Show and Hide References
Contents that refer to other contents are indicated with the Show/Hide References icon.
- Show and Hide Properties
- Repository and Workspace View
For managed libraries it is possible to see all contents belonging to the library (Repository view) or only the content whose documents are retrieved in the current workspace (Workspace view).
- Show/Hide Recycle Bin
The recycle bin works in much the same way as the recycle bin on the Windows operating system. Contents that have been deleted from the library are moved to the recycle bin.
- Find Contents
- Filter Contents
Filter contents by using the Filter toolbar.
- Export Contents
You can export and create a new library with selected contents from your active library.
- Import a Library
- Labeling
Labeling is a convenient way to associate groups of related contents together so they can be easily retrieved and viewed as a set.
- Search for Contents
- Lifecycle Operations
Lifecycle operations include operations such as Get, which retrieves a content to your workspace, and Check-Out and Check-In, which result in versioning of contents.
